Hello Matthias and all,
I'm trying to make a script to count the number of instantiations of each sub cell inside the currently viewed cell using the method "begin_instances_rec". I get some weird results and I can't figure out what's going wrong. I'm (still) using version 0.27.13.
module MyMacro
include RBA
cell_view = layout_view.active_cellview
layout = cell_view.layout
viewed_cell = cell_view.cell
sub_cell_names = []
counter = 0
viewed_cell.called_cells.each do |cell_index|
sub_cell_names << layout.cell(cell_index).name
counter += 1
end # each
sub_cell_names.sort!
line_length = sub_cell_names.map{|string| string.size}.max + 10
puts "Number of cell instantiations in viewed cell \"#{viewed_cell.name}\" (#{counter} different sub cells detected):\n\n\n"
iterator1 = viewed_cell.begin_instances_rec
sub_cell_names.each do |sub_cell_name|
counter = 0
iterator1.targets = sub_cell_name
while !iterator1.at_end?
counter += 1
iterator1.next
end # while
number_of_spaces = line_length - sub_cell_name.size - counter.to_s.size
puts sub_cell_name + " " * number_of_spaces + counter.to_s
end # each
end # MyMacro
Attached a gds test file with 4 top cells:
1) Number Of Cell Instantiations In viewed cell "TOP_CELL_1" (1 different sub cells detected):
CHILD_CELL_1 12
ok
2) Number Of Cell Instantiations In viewed cell "TOP_CELL_2" (2 different sub cells detected):
CHILD_CELL_2 12
CHILD_CELL_2_1 12
ok
3) Number Of Cell Instantiations In viewed cell "TOP_CELL_3" (3 different sub cells detected):
CHILD_CELL_3 12
CHILD_CELL_3_1 12
CHILD_CELL_3_1_1 0
ko ---> 0 should be 12???
4) Number Of Cell Instantiations In viewed cell "TOP_CELL_3_B" (4 different sub cells detected):
CHILD_CELL_3 12
CHILD_CELL_3_1 15
CHILD_CELL_3_1_1 2
CHILD_CELL_3_B 1
ko --> 2 should be 15???
maybe a 'iterator1.reset' is missing before 'iterator1.targets = sub_cell_name'
but I have not tested.
Frank
Hi Frank,
Thanks for the reply. I added the reset but it doesn't change a thing.
I also ran the sample code listed in the documentation (https://www.klayout.de/doc-qt5/code/class_RecursiveInstanceIterator.html) on the attached gds file with top cell "TOP_CELL_3_B" selected and it gives only 2 references as well, instead of 15:
Instance of CHILD_CELL_3_1_1 in TOP_CELL_3_B: r0 *1 120,40
Instance of CHILD_CELL_3_1_1 in TOP_CELL_3_B: r0 *1 120,0
The code is:
@tomas2004 That looks like a bug, probably the arrays are not traversed properly in the recursion. I'll open a ticket. Thanks for reporting that and the testcase.
Regarding your problem: the recursive instance iterator is not the right approach as it will traverse the hierarchy far too often in the general case. You only need to sum up weighted counts, like here:
This gives for "TOP_CELL_3B":
Ticket is here in case someone is interested: https://github.com/KLayout/klayout/issues/1353
Thank you for the improved code. It's indeed very fast :-)
