I'm not sure if there are better ways to do so, but you could create new layer and copy only text shapes there, than remove old layer and set proper layer/datatype to new one.
That's what I was thinking, but the question was how to, in Python.
Did you find that command-series? Or just did it interactive?
I'll repeat a recent question, which is: "Is there a logfile which shows
applied commands in sequence, perhaps even Python / Ruby form,
that "someone" could clip and package up as a script at minimum
effort (like, how I could grab a series of SKILL commands from the
CIW, re-paste them there and see the result repeat in Brand X?)?".
Seems to me that whatever sits there looking at
keyboard & mouse, could be told to yip something
out to a logfile every time it finds a "terminator"
(valid command is satisfied, or an error). That goes
as far as, at least, a historical record.
But the second part would want a mapping from
the foreground command (menu / keybinding, +
args) to an equivalent Python command entered
(where? there's no interpreter?).
So maybe there needs to be a "skinny pipe" from
the "keyboard catcher" to something inhabiting the
script edit / execute environment, that substitutes
the proper Python and then executes. If the plan
was for everything klayout can do, to be doable by
script. Thus making "what I just did" a front door to
script generation. Like how you can "record macro"
in MS Excel, and edit it if you like.
So that's another thing, if you have the history thing
enabled - a "Pythonized Macro Recorder"? If what
would come from the "history catcher" is not actually
executable as-caught, then maybe it's a two-pass-
assembler, like. Catch, then clean.
Now I am also curious about klayout as a purely
pipe-driven (but with live display) engine. I have the
same interest with simulators and schematics, with
the end goal a fully integrated, front-back OSEDA
(my mind still goes back to the happy days of SDA2.0.
Before the dark times. Before the Empire). When men
were men and menus were editable top to bottom
and executable script lay in the CIW hopper, for the
taking.
But I have no knowledge whether "regular klayout"
menu and key-bound commands "go through a
Python grinder" on their way to Doing Stuff, or all the
menus are some other code-base. Which would then
be mondo rip-up.
Hi, Pascal!
Thanks for reply, Eugene. I solved this problem by selecting all shapes -> filtering out all text -> deleting shapes. Problem solved now.
I replied to the other post: https://www.klayout.de/forum/discussion/2295/using-python-script-how-to-delete-all-shapes-in-a-layer-without-deleting-text#latest
An @dick_freebird, no there still isn't because the commands are not routed through some script interpreter, hence they cannot be logged ..
OK, that's understandable I guess.
Let me suggest some things.
taking.
be mondo rip-up.
