"Basic" Library "TEXT" cell
Hello Matthias,
Is the code for the "TEXT" PCell available somewhere?
  • HI tomas2004,
    This should be the code you are looking for, however this seems like not implemented by Py/Ruby API.
    https://github.com/KLayout/klayout/blob/a29bef496af81f1afc1bf3a08ad9fb2eb89890e6/src/lib/lib/libBasicText.cc#L48
    If you want to create text with different font you can use the "TrueType" library from ShapeLib directly.
    https://github.com/jurask/ShapeLib/tree/master
    TrueType text pCell example from ShapeLib:
    https://github.com/jurask/ShapeLib/blob/master/python/text.py
  • @RawrRanger Yes, you're right. The implementation of the Basic Library is C++ and it's similar, but not exactly like the Python or Ruby implementation.
    In order to generate Text from TrueType fonts, you can also use QPainterPath::addText and toSubpathPolygons to generate text polygons.
    However, TrueType fonts are hardly useful for lithographic printing as they are likely to violate a number of design rules.
  • If it was me, I'd be taking those PCell texts and make a process-
    rules-compliant set of every character / numeral / punctuation,
    flatten each one & "make cell" with the character name, and
    never touch them again except to place on layouts.
    I like as few dependencies as possible and flat data is that.
    I won't go to tapeout with parameterized cells.
  • Hello Matthias,
    I've added a new font type (gds file) in the fonts folder.
    Now I would like to instantiate the "TEXT" pcell with this new font type via script.
    This works well via the parameter "font", using 1 instead of 0.
    But what about the parameter "font_name"? Is it the name that appears in the drop down box?
    If I use that one, it doesn't work, I always get the default text (Non-manhattan).
  • For printable characters you really have to stay with "fat stick"
    style or you'll violate groundrules on the little cutesy features of
    (say) a Times New Roman font. In my experience you're lucky
    to get "big and little". I have never seen anything remotely "pretty".
  • Thanks, but I mainly use segmented labels because of tight maximum width rules or else Manhattan style labels...
  • edited September 19
    @tomas2004 The name of the font should be the name of the file sans extension (e.g. "myfont.gds") should become available as font with name "myfont".
    Basically "font_name" should have priority if it is a valid name. If "font_name" is not valid, the index is taken and that allows little control over the font actually used. Which is not entirely true as the Basic:TEXT cell is based on "TextGenerator" (https://www.klayout.de/doc-qt5/code/class_TextGenerator.html) which has an API for font queries and it also provides a way to register fonts programmatically from arbitrary sources.
  • Hi Matthias,
    Got it! Works well, but I will use the TexGenerator from now on... :D
  • Very good :) The TextGenerator was created so that users do not necessarily have to use the PCell.
  • Hi Matthias,
    I noticed that a new line "\n" in the string "text" parameter results in a space making the "line_spacing" parameter kinda obsolete (at least in version 0.27.13). Can you verify?
  • edited September 30
    Hi Thomas,
    the "\n" needs to be embedded into the string - so you need to use "LINE1\\nLINE2".
    There reason is probably that I wanted that you can enter "\n" into the text edit box of the TEXT PCell which is not multi-line capable.
