Can anyone tell me what this error message is, and if there's any way to resolve it? I'm trying to read in a gds file created on another application. It must be messing up a field that klayout needs, but I can't tell what it is.
It looks like the exception was thrown from:
The function signature implies that when creating a new cell (from your GDS2 file),
a cell name might be missing (empty).
A buddy command line tool,
strm2txt
, would help.An example run of
strm2txt
Since you are using a Mac version, see the instructions shown below.
I'll give it a shot, sekigawa-san. Thank you
@BillG and @sekigawa "strm2txt" may not work as it reads the file before writing it as text and the reader will fail already.
For the purpose of debugging file issues I created a direct conversion tool (https://github.com/klayoutmatthias/dump_oas_gds2). However, there are only sources, no binaries. There is a Makefile which should be good enough for most cases, but building it is in particular easy on Linux.
Hello @Matthias,
I understand it. I'll try to make the debugging tools in different environments.
Kazzz-S
Hello @BillG,
I could build the above dump tools on
macOS Monterey
using Apple clang version 14.0.0.===> https://github.com/klayoutmatthias/dump_oas_gds2/issues/2#issuecomment-1863817572
If you need the executables (for Intel Mac), I can provide you with them.
I also found another simple GDS2-->ASCII dump tool in Python suggested by ChatGPT.
I have modified the original code a bit.
===> https://github.com/Kazzz-S/gds2ascii-tool-project
1.
dump_gds2 testdata/gds/t10.gds
2.
gds2ascii.py testdata/gds/t10.gds
Kazzz-S
I have fixed the bug of
gds2ascii.py
.2-retry.
