Hi everyone,
I'm relatively new to KLayout and recently encountered a problem with layer visibility. After importing my GDSII file, some of the layers aren't displaying correctly in the layout view. I've checked the layer properties and everything seems to be set up correctly, but the issue persists.
I also check this : Changing The Layer VisibilityrubyBut I ahve not found any solution.
Maybe the "Show Layers Without Fill" box in the "View" menu is checked...If so, just uncheck it...
Could you share a screen shot of the application window?
Layers with no content will "act funny".
