Hi sir,
as this picture , Can I make modify for the path P2/P3 using a mouse moving, but keep P1/P4 by coordinate?
As some of GDS editor , we can select one of edge in a path to modify base on mouse moving not a coordinate editor.
I hope this is OK with you.
Hi sekigawa-san
Yes!! it is what I need .
Hi Sekigawa-san,
It is possible to modify (move a single path seg which I selected ) just 1.um by x-axis or any value what I key in?
Hi @jiunnweiyeh,
yes, if you partially-select a piece of a path, you can use "Edit/Move By" to key in a distance you want to move the selected segments or points by.
