When I do “File -> Import Cadence Tech File” the tool generates a syntax error. I’ve included a screenshot. I’m trying to read the 12LP_13M_3Mx_2Cx_4Kx_2Hx_2Gx_LB_84cpp_tech.lef file using the procedure specified in the OpenRoad documentation. This techfile can be read into Innovus without any problem.
I think I'd begin (presuming this is an ASCII techfile)
with finding and inspecting the flagged line for odd
qualities that the import might choke on.
For example Brand X is prone to be verbose and long-
winded, and the line might exceed a baked in import
line length limit like if is the sought "]" there, but line is
133 and not <=132 char, or whatever). Or maybe some
clever PDK developer found a continuation character
that the import script didn't know about.
Expect the problem can be "fixed" at the source, if it
was a legit techfile that worked to begin with.
Best is, you start with an exported ASCII techfile.
I don't know exactly what you are trying to import. This appears to be something binary or maybe it is a Skill-enhanced techfile.
Thanks for the reply!
The LEF techfile I'm trying to read is indeed ASCII. Here's an obfuscated excerpt which shows line 865:
861 PROPERTY LEF89_SPACINGTABLE "
862 SPACINGTABLE
863 LAYER A1
864 CENTERTOCENTER B TO YQWE BRTY TO YQWE BQWE TO Y BQWE TO YRTY BQWE TO YQWE
865 CENTERANDEDGE B TO Y B TO YRTY BRTY TO Y BRTY TO YRTY
866 PRL 0.123 MAXXY B TO YQWE 0.45 BQWE TO Y 0.67
867 CUTCLASS B BRTY BQWE
868 Y 0.789 0.012 0.889 0.012 0.345 0.345
869 YRTY 0.749 0.012 0.709 0.012 0.698 0.678
870 YQWE 0.395 0.345 0.678 0.608 0.678 0.978 ; " ;
I tried shortening lines 864 and 865, but the syntax error remains. My knowledge of DEF syntax is admittedly limited, but I don't see any obvious problems with the line in question (or the one before it). It looks very similar to other SPACINGTABLES defined elsewhere in the file.
Any ideas?
This feature reads Virtuoso techfiles, not technology LEF files.
