I'm trying to run LVS on a subblock of tiny tapeout and for most of them it works fine. However when trying to do the same for the "mux" part
(which selects/mux signals between a row of projects), this doesn't. It looks like it's not completing. It's been running for 1h30 now ... (while the others blocks are a minute or two at most).
I've attached the input files and LVS script we're using.
Sylvain
Actually I think the CDL written out by OpenROAD is incorrect.
Of course it's still be nice if KLayout reported a LVS mismatch instead of not finishing
Of course
In most cases, "stuck LVS" comes from ambiguities - manifold parallel nets that share the same signature. This is typical for buses for example. In that case, helping LVS with proper net labels helps.
But I will check if that is the case there and if something can be done. Thanks for the test case.
Then that event might trigger some "introspection" or whatever.
Attached is a new CDL which I think is correct.
OpenROAD had a bug, I think I fixed it but LVS still isn't proceeding. I didn't wait as long yet, but in 15 min, still no results.
EDIT: CDL definitely looks correct. I was actually able to match it against the netlist extracted by klayout using netgen.
grml .... found the issue.
So here is the story:
You can turn on noisy debugging in the netlist compare code when you set
It shows the backtracking algorithm goes into tentative evaluation due to massive ambiguities like this:
that translates into "the names do not give me a clue" because one name (layout) contains square brackets, the other (schematic) doesn't.
In the CDL file the brackets are there.
I then debugged my own code without finding anything that removes the brackets. They simply are not there.
That was until I looked into the LVS script which has this code (line 243++):
In other words, it clears all square brackets, dollars and slashes. I don't know why.
After removing that line, LVS gets the hints it needs from the layout labels and passes in a little more than 12 seconds.
Great.
\o/ Matthias you rock !
Indeed with that change it checks out in no time at all.
I've pinged the ihp folks about that, we'll see what they say ...
