gds file with electrical layers
I am using xic for schematic capture and LVS/DRC, which stores the schematic in some gds layers. trying to import the layers in Klayout. I changed the lyp file .. the electrical layers from the xic gds file don't show up and a Klayout write to gds file don't include the electrical layers.
Thank you.
  • If you have no technology defined and no .lyp loaded
    (clean start) then streaming in your gds file would
    import every found layer/purpose pair.
    Now you can inspect for those "xic" layers, and you
    could save the layers to a new .lyp for "friendliness
    editing". Then you can make that the root of a
    "Technology" (to keep handy) and export should
    just write out a file same as came in.
    Try that out and see where (if) any problem lies.
