There is not straightforward "cut" function, but you can use "erase" background combination mode to draw a thin line across your shape. This line will then be subtracted from your shape basically creating two separate parts.
Another way is to employ a mask - for example draw a box over one half of your shape. Copy the original shape to the clipboard (Ctrl+C), subtract the mask from the your shape (Edit/Selection/Subtraction) to get the outside half. Then paste the original shape and repeat the process with Edit/Selection/Intersection to get the other half.
Is it possible to use this way to substract a part of a layout?
If I have an instance of dots and I want to remove some of the dots in the center to produce a certain shape, or rather I have dots arranged in a square and would like to remove part of the dots in the center.
I'd use the layer subtraction function in the boolean operation set. You could create a temporary layer, draw a shape (rectangle, polygon ...) where you want to remove the dots and use Edit/Layer/Boolean Operation with
Layer A: the layer with the dots
Layer B: the temporary one
Mode: A NOT B
Output: to the dot layer
This will remove everything under the temp layer shapes. Please note that if you created a dot array using instance arrays, the dots will be propagated to the top cell creating some amount of shapes (not instances) in the top cell.
This would help a lot in the work I am doing now.
Br
/thomas
Hi Thomas,
/Thomas
