Hello, I am relatively new to Mac.
I have Klayout under Applications (as typical, I think), but where would I put the .rbm file to make it appear in the menu?
Quite often I see description as below:
It is possible however, to implement such a function in ruby. Just copy the code below to a file with extension .rbm (i.e. compute_area.rbm) and copy that file into the installation directory of KLayout. It will add a new entry to the "Tools" menu which computes the area of all objects selected.
I know what to do in Windows, but since I'm using a Mac now, any ideas?
Thank you very much for your help.
Jack
Hello Jack,
I think there are several ways to achieve what you want to do.
Perhaps, the simplest way is to set "KLAYOUT_PATH" environment variable.
Assuming that you are using the binary package for Mac, you may edit the Bash
script file that invokes KLayout.
For example, if you want to place *.rbm files under ${HOME}/temp directory, add
[Ref. Dropbox]
https://www.dropbox.com/s/zagsv4d8sv8f0tp/2015-1008-Jack.png?dl=0
The image shows such an example where I added some customized menus by *.rbm files.
Hope this helps you.
Kazzz
Thank you for your help.
I found another way: Show the package contents of Klayout, and copy the .rbm file to MacOS folder, then it's done!
Jack
