Ruler issue after klayout v0.21(included)
edited December 2010 in KLayout Support
Hi Matthias:
The ruler after v0.21 seems malfunction, when we try to setup the ruler as follow, the errors appear in terminal:
Rulers And Annotations => Templates => Outline
from Diagnoal to Horizonal and vertical (in this order)
*** ERROR: Unknown variable 'x' at '..{%.2f}'
*** ERROR: Worker thread:Unknown variable 'x' at '..{%.2f}'
The same setting works fine on v0.20, could you please confirm that ? thanks~
Best Regards,
chhung
  • edited December 2010
    Hi Matthias:
    We found that the X Label format $x{%.2f} is no longer accepted after v0.21, changed it to $X fixed this issue.
    Best Regards,
    chhung
    Hi chhung,
    I forgot to mention that new feature in the release notes. Actually, I replaced the simple substitution scheme by a full-blown expression parser. The new scheme is described here: http://klayout.de/short_um.html#ruler_properties.
    Frankly I reckoned not many people would use the old scheme and did not spend the effort to provide something backward compatible. To emulate the old "$x{%.2f}" you now can use
    $(sprintf('%.2f',X*1000))
    For a brief explanation: the former lower case 'x' is actually X in nm units, hence X*1000, the formatting is done with sprintf rather than the somewhat non-standard {..} notation.
    If it's important I can try to implement a fallback scheme that is backward compatible.
  • edited 2:55PM
    We really appreciate your explanation about ruler issue in detail, the new scheme is good enough for us, thanks for your effort.
    Best Regards,
    chhung
