Hi Matthias:
The ruler after v0.21 seems malfunction, when we try to setup the ruler as follow, the errors appear in terminal:
Rulers And Annotations => Templates => Outline
from Diagnoal to Horizonal and vertical (in this order)
*** ERROR: Unknown variable 'x' at '..{%.2f}'
*** ERROR: Worker thread:Unknown variable 'x' at '..{%.2f}'
The same setting works fine on v0.20, could you please confirm that ? thanks~
Best Regards,
chhung
We found that the X Label format $x{%.2f} is no longer accepted after v0.21, changed it to $X fixed this issue.
Best Regards,
chhung
Hi chhung,
I forgot to mention that new feature in the release notes. Actually, I replaced the simple substitution scheme by a full-blown expression parser. The new scheme is described here: http://klayout.de/short_um.html#ruler_properties.
Frankly I reckoned not many people would use the old scheme and did not spend the effort to provide something backward compatible. To emulate the old "$x{%.2f}" you now can use
For a brief explanation: the former lower case 'x' is actually X in nm units, hence X*1000, the formatting is done with sprintf rather than the somewhat non-standard {..} notation.
If it's important I can try to implement a fallback scheme that is backward compatible.
We really appreciate your explanation about ruler issue in detail, the new scheme is good enough for us, thanks for your effort.
Best Regards,
chhung
