I've tried importing many different versions of Numpy none of which seem to work.
Does anyone have a whl file for a version of Numpy that is compatible.
Thanks in advance.
Bellow is the error I get executing any macro that makes use of numpy.
Importing the multiarray numpy extension module failed. Most
likely you are trying to import a failed build of numpy.
If you're working with a numpy git repo, try `git clean -xdf` (removes all
files not under version control). Otherwise reinstall numpy.
Original error was: cannot import name 'multiarray'
are you using Windows?
On Linux, usually it's sufficient to add the specific package to make it available for KLayout too.
On Windows, things are a bit more complicated. On Windows, you'll need a binary builds that are compatible with the host interpreter. There are various compilers and runtime systems, so you need to find the fitting one.
The standard binary is built with MSYS2, so if you install this plus the NumPy package, you may be able to use it with KLayout too.
Hi Daanyaal,
On CentOS-7 the following worked for me:
This installed numpy-1.13.3. Then in KLayout, no problem running "import numpy" and numpy commands.
Hi luKasc,
can you expain to me how did you add the numpy in windows klayout.
thanks
