Hi @SRF,
The current macOS
build4mac.pybuild system does not officially support Monterey.However, I hope it still works.
Kazzz-S
Edit 2025-02-23:
./build4mac.py -q qt5macports -r mp33 -p mp312build command (Fully MacPorts-flavored build), editmacbuild/build4mac_env.pyas below.Hi @SRF,
Kazzz-S
Hi @SRF,
I recently upgraded my development environment to
Sequoia 15.5 + Xcode 16.4 + VMware Fusion 13.6.3. See this ticket.I also noticed that the view count of this post increases gradually.
To reconfirm again that the source code build in Monterey is still possible, I attempted the two builds for
KLayout 0.30.2with the latest MacPorts packages.I uploaded two DMGs here for your reference.
Kazzz-S
I've noticed that the number of views for this post is still gradually increasing.
KLayout 0.30.3with the latest MacPorts packages.I uploaded two DMGs here for the community's reference.
Kazzz-S
I have made another attempt to build version
0.30.4on macOS Monterey (Intel).I have uploaded two DMGs for the community's reference, which you can find here.
Unfortunately, the latest macOS version,
Tahoe, no longer supports my 13" Intel MacBook Pro (2019 model).The machine's life is also nearing its end. :-(
Kazzz-S
I made another attempt to build version
0.30.5on macOS Monterey (Intel) to see if the overhauled build system forARM64+Tahoealso works on Monterey.I have uploaded two DMGs for the community's reference, which you can find here.
Kazzz-S
I've uploaded two
Version 0.30.6 DMGsfor the community's reference; you can find them here.Kazzz-S
Hi Kazzz,
thanks for your efforts to support Monterey! Does it make sense to upload the DMGs on the server or is okay to leave them in your place?
Hi @Matthias,
When I first responded to this post, I intended to just provide a one-off example of how it could be built for Monterey.
Since then, I've found myself creating DMGs for 6 versions (0.29.11, 30.2, 30.3, 30.4, 30.5, and 30.6).
As you suggested, I think it would be better to archive these DMGs on the official servers.
The downside is that they wouldn't seamlessly support all versions...
Kazzz-S
I've uploaded two
Version 0.30.7 DMGsfor the community's reference; you can find them here.Also see this link.
Kazzz-S
I've uploaded two
Version 0.30.8DMGs for the community's reference; you can find them here.Now, MacPorts' Ruby version is 3.4.9.
Also see this link.
Kazzz-S
I've uploaded two
Version 0.30.9DMGs for the community's reference; you can find them here.MacPorts' Ruby version is 3.4.9.
Also see this link.
I've uploaded two
Version 0.30.10DMGs for the community's reference; you can find them here.MacPorts' (Ruby, Python) version is (3.4.10, 3.14.6).
Also see this link.
I've uploaded two
Version 0.30.12DMGs for the community's reference; you can find them here.MacPorts' (Ruby, Python) version is (3.4.10, 3.14.7).
Also see this link.
I've uploaded two
Version 0.30.13DMGs for the community's reference; you can find them here.MacPorts' (Ruby, Python) version is (3.4.12, 3.14.10).
Also see this link.
I've uploaded two
Version 0.30.14DMGs for the community's reference; you can find them here.MacPorts' (Ruby, Python) version set is (3.4.13, 3.14.10).
Also see this link.
