top cell set criteria
What is the criteria which cell will be on top?
It does not look like an alphabetical order, I try to avoid having scripts and .lym session files to keep the top cell setting.
  • Isn't it the cell that was visible at the time of saving the file? Can you check? (I didn't).
  • There can be multiple 'top' cells. Top just means that a cell has no parent cell. Which is usually the case when you write/export a gds file.
    Some documentation: (ctrl-f top and you'll find it)
    https://www.klayout.de/doc-qt5/programming/database_api.html
    And here's a good article about gdsII format:
    https://www.artwork.com/gdsii/gdsii/
    Sadly I don't know how kLayout picks a top cell if there are multiple of them...
  • I can tell :)
    When there are multiple top cells, KLayout picks the one with the largest bounding box for initial display. GDS does not have a way of saying which is the primary top cell. Also, GDS files with multiple top cells are common only in certain contexts (e.g. as a collection of library cells). A design ready for tapeout should never have multiple top cells.
  • Many orgs seem to have a habit of calling the
    top cell "TopCell". When you do part after part
    after part, you can stand to lose a few repetitive
    questions. If you get to name the baby, then you
    might develop a habit that saves thought. I will
    often designate "real important stuff" with a
    "00_blahblah" type name so that alpha ascending
    sort will bubble them to the top. That's personal,
    not common practice, but works for me. Also
    tagging stale versions with date suffix (rename
    and copy-back) gives me a "trail" that is poor boy
    "versioning".
    Or make a "TopCell" or "00_Top" layout that has
    placed, the "real" one and just push in. Change
    your mind? 00_Top2.
