Hi, recently I am thinking how to export the layer under certain situations, the codes below can show all the layer from this gds file
However, if my gds file has two hierarchies and the second hierarchy has a cell name "abc" if I do not want the the layer information of abc shows in my code, how can I do it? I guess hide "abc"
but how to do it in python code?
Best wishes
Muheng
Hi Muheng,
the concept of layers is orthogonal from the cells. So a layer is a property of the layout, not of the cell. By asking the layout for the layers, you cannot exclude cells from the information.
You could analyse your cells for shapes in a given layer using "cell.shapes(layer_index).empty?". This will give you information about what cell has shapes in which layer.
Hi,Matthias,
thanks for that. BTW, I attached a image, assume my gds file is ABC, I have 3 cells under my ABC, which are
qqq
www
eee
if I want to have a look qqq has layer No.1 or not, I guess I can type
"cell.shapes(layer_1).empty?" to check, here "cell" is qqq, right?
but how to get the qqq in python?
is that right?
Also, I am not sure about the "?" is OK for the python script
Hi Muheng,
In Python this will be
