export layers from a gds by hiding a cell?
Hi, recently I am thinking how to export the layer under certain situations, the codes below can show all the layer from this gds file
  • import pya
  • layout = pya.Layout()
  • layout.read('BDE.gds.gz')
  • for ly_id in layout.layer_indices():
  • ly_info = layout.get_info(ly_id)
  • print(ly_info.to_s())
However, if my gds file has two hierarchies and the second hierarchy has a cell name "abc" if I do not want the the layer information of abc shows in my code, how can I do it? I guess hide "abc"
but how to do it in python code?
Best wishes
Muheng
  • Hi Muheng,
    the concept of layers is orthogonal from the cells. So a layer is a property of the layout, not of the cell. By asking the layout for the layers, you cannot exclude cells from the information.
    You could analyse your cells for shapes in a given layer using "cell.shapes(layer_index).empty?". This will give you information about what cell has shapes in which layer.
  • Hi,Matthias,
    thanks for that. BTW, I attached a image, assume my gds file is ABC, I have 3 cells under my ABC, which are
    qqq
    www
    eee
    if I want to have a look qqq has layer No.1 or not, I guess I can type
    "cell.shapes(layer_1).empty?" to check, here "cell" is qqq, right?
    but how to get the qqq in python?
    • import pya
    • cell=layout.cell_name("qqq")
    is that right?
  • Also, I am not sure about the "?" is OK for the python script
  • edited October 2018
    Hi Muheng,
    In Python this will be
    layout.read("yourfile.gds")
    cell = layout.cell("qqq")
    layer = layout.layer(1, 0)
    if cell.shapes(layer).is_empty():
      print("Cell qqq in empty with respect to layer 1/0")
