I'm now developing a plugin upon KLayout.
In this plugin, I will use classes, such as QChart, of Qt Charts module. Currently there is no corresponding interfaces of KLayout.
It seems the classes with prefix gsi* are automatically generated by some tools.
So Is there any way to also expose classes of Qt Charts to Python?
Hi William,
there is, yes. The script which generates these declarations is in scripts/mkqtdecl.sh. But that's not straightforward. It's not generalized yet, so it works on two baseline Qt versions, namely 4.6.3 and 5.5.1 which have to be installed under /opt/qt/4.6.3 and /opt/qt/5.5.1 respectively. It relies heavily on customization through configuration files (scripts/mkqtdecl4/mkqtdecl.conf and scripts/mkqtdecl5/mkqtdecl.conf). So adding a new module is possible, but comes with a lot of customization work.
But let me tell you, that the Qt integration was intended as a lightweight feature to extend the UI to a certain degree. Complex user interfaces have not been the scope of this activity. It came as a spin-off from the script language integration. As it competes with pyqt and I sense little public interest in the feature as a whole, I am not supporting that with high priority. Experience also tells me that doing so will create additional support demand, which I am not able to deliver in the framework of a non-profit project.
Hi, Matthias
I get it. Thanks for your comment.
William.
