Hi
I am not sure if the following is possible.
I have a GDS file and a file contains a list of locations in the given GDS file. I would like to use klayout to load the GDS file, then somehow load the list of locations, and then "step through" (by clicking a button or use some short cut key) of each location. basically I want to move the klayout window to each of those locations. Is there a way to write a python script to do that?
sure! This is possible! I hacked a snipped for you that allows you to cycle through locations by pressing Ctrl+n:
What you need to do is: create a new Python macro and paste the code into it. Further there are some TODOs in the code. You may want to change the lines near them. For instance you need to load your locations. I didn't know anything about the file format so I just put a dummy list of locations.
really appreciate it. I will try it.
I would use the Tools->Marker Browser that's used to load .rdb error files, it not only has "step thru" functionality, but also markers ..
thanks for this lively discussion :-)
The marker browser is exactly build for this purpose. If you're able to format the list of coordinates in it's XML format, you're done. It's also possible to fill a marker database using a script and show this one. There is a discussion where I explained how: https://www.klayout.de/forum/discussion/comment/786#Comment_786. This script is somewhat outdated now, but the RDB concepts are still the same.
There is a screenshots gallery on the sample page: https://www.klayout.de/examples/screenshots.html. Maybe you like this way too. It's a graphical way to select a specific location.
Never mind. I found the description by using google:-) It's in https://www.klayout.de/rdb_format.html
I will try to use the "Marker Browser". However, I didn't find the description of the rdb file format. Is there some description on the file format? a casual search didn't find anything
Steven
Hi Steven,
ver good :-)
I wonder why Google won't find it - the RDB description is properly linked from the main page: https://www.klayout.de/rdb_format.html.
