I Zoom In to a specific section in a cell (Cell-1) and then look at another cell (Cell-2). When I get back to Cell-1, the view is resets to Zoom Fit. Is there a way to turn this feature off and keep each cell's view where I leave that?
the option is found in "FIle/Setup", "Navigation/New Cell" page: turn off "Fit Windows to cell when cell is changed".
Hi Matthias. That partially solved the problem. Now Zoom level is not reset but it brings all the cells to the same zoom level. If I am working on two cells with on Zoomed In and other Zoomed Out, I still have to keep adjusting their view while switching between them.
So you say you're expecting that every cell has it's own zoom level? That's not the case - there is a just a global one.
But you can actually open a single layout twice with different cells in two tabs:
1.) Open a layout
2.) Open an empty tab with "File/New Panel"
3.) Duplicate the layout into the second tab with "File/Pull in other layout"
4.) Select one cell in the first tab and the other cell in the second tab
You can edit a cell in one tab and another cell in the other tab. Both zoom levels are independent.
