I have just built klayout 0.25.9 on my mac (10.14.4). It was successful (no errors), but I couldn't open it. It says:
"klayout cannot be opened because of a problem."
And
Dyld Error Message:
Library not loaded: libklayout_tl.0.dylib
Referenced from: /Users/USER/*/klayout.app/Contents/MacOS/klayout
Reason: image not found
Details:
I followed the instruction on website, where tar hzxvf klayout-*.tar.gz
threw an error because option h
and x
conflicted so I removed h
for extraction.
My environment:
Using qmake: qmake
Using Qt 5 API
Using Ruby interpreter: ruby
Ruby library found: /Users/xyan/anaconda3/lib/libruby.2.4.5.dylib
Ruby headers found: /Users/xyan/anaconda3/include/ruby-2.4.0 and /Users/xyan/anaconda3/include/ruby-2.4.0/x86_64-darwin17
Ruby installation is in:
- /Users/xyan/anaconda3/lib/libruby.2.4.5.dylib (lib)
- /Users/xyan/anaconda3/include/ruby-2.4.0 (headers)
- /Users/xyan/anaconda3/include/ruby-2.4.0/x86_64-darwin17 (arch headers)
Ruby version code is 20405
Using Python interpreter: /Users/xyan/anaconda3/bin/python
Python library found: /Users/xyan/anaconda3/lib/libpython3.7m.dylib
Python headers found: /Users/xyan/anaconda3/include/python3.7m
Python installation is in:
- /Users/xyan/anaconda3/lib/libpython3.7m.dylib (lib)
- /Users/xyan/anaconda3/include/python3.7m (includes)
Features:
Qt bindings enabled
Installation target: /Users/xyan/klayout-0.25.9/bin-release
Build directory: /Users/xyan/klayout-0.25.9/build-release
Building plugins:
Running qmake ..
QMake version 3.1
Using Qt version 5.9.7 in /Users/xyan/anaconda3/lib
and Clang:
Apple LLVM version 10.0.1 (clang-1001.0.43.3)
Target: x86_64-apple-darwin18.5.0
Thread model: posix
Thanks in advance!
xyan
I also tried running
make
after building, butHi,
Building KLayout (0.25 and later) on Mac OS is a bit complicated task.
You need to resolve dependencies among many libraries and binaries.
I have mimicked what you wanted to do on my Yosemite (still!) with anaconda3.
Please refer to https://github.com/Kazzz-S/klayout/issues/34 for details.
Hope this will help you in your Mojave environment, too.
Kazzz-S (Kazunari)
Hello Kazzz,
Thank you so much for the very detailed instructions. I have built successfully and I was able to open klayout.
There was a small problem though. When I checking the python console in Macros Developments, I ran into an error when trying to import numpy. The error message is as follows:
Then removed my numpy and reinstalled via
conda install
and it solved the problem. The reason I mention this is because that this error message looks very similar to what I had before, so now I suspect that my previous problem was also due to this numpy issue (?).Anyway, thanks so much for your help. I can use klayout for my applications now.
Best,
xyan
