I have recently upgraded to the new Mac OS and can't get kLayout to start any more.
Initially it could not find the Ruby framework anymore, as that got updated in the new release. I could (presumably) resolve this issue after some search by pointing kLayout to the new framework location via
install_name_tool -change /System/Library/Frameworks/Ruby.framework/Versions/2.3/usr/lib/libruby.2.3.0.dylib /System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/lib/libruby.2.6.dylib /Applications/klayout.app/Contents/MacOS/klayout
and
install_name_tool -change /System/Library/Frameworks/Ruby.framework/Versions/2.3/usr/lib/libruby.2.3.0.dylib /System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/lib/libruby.2.6.dylib /Applications/klayout.app/Contents/Frameworks/libklayout_rba.0.dylib
However, now when starting kLayout, I run into
Dyld Error Message:
Symbol not found: _rb_cFixnum
Referenced from: /Applications/klayout.app/Contents/MacOS/../Frameworks/libklayout_rba.0.dylib
Expected in: /System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/lib/libruby.2.6.dylib
which I presume is due to an incompatibility between Ruby versions.
I obviously don't really know what I am doing here, any help appreciated.
Any idea for a fix?
Cheers.
Here is what worked for me. Basically installed Ruby 2.3.0 and linked Klayout to it as you did.
1) Update Xcode through App Store
2) Accept licence:
sudo xcodebuild -license accept
3) Install the Xcode Command Line Tools
xcode-select --install
4) Make sure it worked with brew:
brew doctor
5) Install RVM
\curl -sSL https://get.rvm.io | bash -s stable --ruby
6) To start using RVM you need to run: (!!!change USER to your username)
source /Users/USER/.rvm/scripts/rvm
7) Install ruby 2.3.0
rvm install 2.3.0 --with-openssl-dir='brew --prefix openssl'
8) Change Path to RVM installed ruby: (!!!change USER to your username)
install_name_tool -change /System/Library/Frameworks/Ruby.framework/Versions/2.3/usr/lib/libruby.2.3.0.dylib /Users/USER/.rvm/rubies/ruby-2.3.0/lib/libruby.2.3.0.dylib /Applications/klayout.app/Contents/MacOS/klayout
install_name_tool -change /System/Library/Frameworks/Ruby.framework/Versions/2.3/usr/lib/libruby.2.3.0.dylib /Users/USER/.rvm/rubies/ruby-2.3.0/lib/libruby.2.3.0.dylib /Applications/klayout.app/Contents/Frameworks/libklayout_rba.0.dylib
Thanks, a variant of that worked for me too, did not know about rvm..
Hi Mattiahalter,
I wanted to install klayout on my Mac (OS Catalina) but it didn't work out due to the compatibility issues. So I followed your steps except for no.4 (brew doctor) which i simply typed in Terminal but command failed - I never worked with coding, so I am Alien at this planet
could you please walk me through step 4? what i need to do to install Klayout successfully. Thanks.
Maybe you can join the discussion on GitHub here: https://github.com/KLayout/klayout/issues/381
There are some links to installation files and I got some feedback these are working.
@Matthias, Great It worked out. Thanks a lot.
Regards, Adnan
