I am using Klayout 0.26.3 at work.
When I tried to open a recently-completed gds (311 KB), I get this error "XY record expected (position=305244, record number=11690, cell=test)".
I guess the file must have got corrupted when my laptop went to sleep while KLayout was still open.
Can anyone advise if it is worthwhile to try a repair by hex editing or should I redo the gds ?
Unfortunately I am not allowed to share the gds file for inspection.
Thanks !
I tried out Glade and Layout Editor, both could open the gds successfully.
Then saved to gds again, and now Klayout can also open the new gds.
Problem solved.
Evidently klayout likes strict GDS format compatibility even
in things like byte-counts of fixed format fields. Other tools
may have some "checking and healing" features that let this
kind of thing slide, and reformat the output with proper dummy
/ packing on export?
Hi wimbur,
going to sleep should never damage a GDS. The GDS gets saved during "Save", that's it.
There are ways to damage a GDS, like saving too big polygons (>8k points) without limiting their vertex count (see writer options). Or if your disk is full and the file gets truncated.
