If i run the DRC script on a big cells, it works several times without any problem.
I need it because after some layout corrections, I need to re-run DRC to check them, then loop again and again ...
But after a several time the memory get full because all runs results are kept in memory.
Is there a way to purge the previous DRC run results from memory ?
BRgds,
Hi Laurent,
yes there is
In the marker browser's "File" menu (top right button) chose "Unload all" to purge all results
