Dear all,
I have a fairly fundamental question: When I select or double-click a cell instance, I do NOT want to access objects defined in the cell, I want to access the properties of the instance, such as placement, scale, orientation, array, etc.
Now what ever I do goes in as editing the cell definition, very frustrating.
Where in the Settings can I change this?
I probably lack the terminology for this...
BN
Hi BN,
By default you're in "Edit in place" mode which means you access all objects regardless of the level of hierarchy.
To access the instances, you have two options:
Exactly what I needed.
Sorry to answer and say thank you so late.
