We enabled wide coordinates(64bit) to build klayout(0.26.5) and it's ok to
open a high precision(200000) db, however once we try to use
marker browser to open a RVE file which is DRC result of this db,
it failed and showed the following error message:
ERROR: Range overflow on integer (line=21)
The line 21 of this file is
841707000 2246332500
I guess the Y value "2246332500" is over the long positive integer limit(2147483647),
is there any way to fix it?
Really thanks for your kindly help~
chhung
Hi chhung,
yes, your observation is correct.
For fixing it, the code needs to be patched. It always uses "int" for coordinates. I have created a ticket for this: https://github.com/KLayout/klayout/issues/554. There is a PR already with the patched (branch issue-554). If you want you can try this one.
This patch could be applied on v0.26.5 , v0.25.9 , v0.24.10 and tested OK
Thank you so much
Best Regards,
chhung
