I have a LEF where I've put a property on a VIA in LEF. When I load this into KLayout I get:
ERROR: ./util/def2gds.py:10: Expected token: END (line=1978, cell=, file=14lppxl_13m_tech.lef) in Layout.read
./util/def2gds.py:10 (class exceptions.RuntimeError)
The relevant line is:
PROPERTY OR_DEFAULT 1 ;
I looked at dbLEFImporter.cc and I didn't spot any support for properties on vias. I can generate a test case if needed but this seems to be an omission. No other tools have had an issue with this LEF.
Could you please provide more context? Like where this property line appears? Ideally you would provide a short test file that reproduces the problem.
LEF/DEF underwent some heavy refactoring recently, but this new version is not finalized yet. I can try if this problem vanishes with this branch.
I will put one together but it is just inside a VIA statement in LEF. Btw, why write your own parser when Si2 provides an open source parser (https://si2.org/oa-tools-utils-libs/)
This is a minimal LEF to reproduce the problem. I'm not sure how to upload an attachment or I would provide a more complete test case. Thanks.
VERSION 5.6 ;
UNITS
DATABASE MICRONS 2000 ;
END UNITS
PROPERTYDEFINITIONS
VIA OR_DEFAULT STRING ;
END PROPERTYDEFINITIONS
LAYER metal1
TYPE ROUTING ;
END metal1
LAYER via1
TYPE CUT ;
END via1
LAYER metal2
TYPE ROUTING ;
END metal2
VIA via1_4 DEFAULT
LAYER via1 ;
RECT -0.035 -0.035 0.035 0.035 ;
LAYER metal1 ;
RECT -0.035 -0.07 0.035 0.07 ;
LAYER metal2 ;
PROPERTY OR_DEFAULT Y ;
END via1_4
END LIBRARY
There is an "attach file" button (the "document" thing) in the comment editor. Wrap it all in a .zip file, so it gets accepted as a legal file format.
And you don't need to point me to Si2 sources. I know them well. If this means you volunteer for integrating third-party code into KLayout and maintaining this solution, you're welcome to do so. I'd be really happy to drop that crap from the source base. But please don't expect me to justify my decision not to use their code.
I only just noticed this reply now. I didn't mean to offend and am not asking you to justify your decision.
I tried to attach the above as test.lef but it appears that .lef is not an accepted extension. Do you want it as a .txt?
No offense taken and sorry for this reply. I don't recall why exactly I wrote that this way, but let's just assume it was the weird COVID situation by then ...
