I use the following ruby script to save my net trace result with specified layer to a new cell, but I face some problem.
Its layer id saved in class NetElement is not a valid layer index in the layout I parse in.
The layer id would be 10^9+1.
I guess the reason is the net trace result is built from the LOP NOT(i.e., "MetalDown_NOT_CutMetal") defined in the symbol, not the original layer in the layout.
And I haven't found any function to get the layer/datattype # or naming in the symbol of this layer yet.
Is there any way to do such a thing?
The Klayout version I used is 0.25.8
The script:
layout = RBA::Layout::new
layout.read("trace.gds")
tech = RBA::NetTracerTechnology::new
tech.symbol( "MetalDown_NOT_CutMetal", "1/0-4/0")
tech.connection( "MetalDown_NOT_CutMetal" , "2/0", "3/0")
tracer = RBA::NetTracer::new
tracer.trace(tech, layout , layout .top_cell, RBA::Point::new(0/layout.dbu, 0/layout.dbu), layout.find_layer(1, 0) )
trace_result_cell = layout.create_cell("trace_result")
tracer.each_element do |e|
###try to save MetalDown_NOT_CutMetal only, but failed
e_layer_info = layout.get_info(e.layer)
if e_layer_info.layer == 1 && e_layer_info.layer == 0
trace_result_cell .shpaes(e.layer).insert(e.shape,e.trans)
###trace_result_cell.shapes(layout.layer(5,0) ).insert(e.shape,e.trans)
layout.write("check_result.gds")
any chance to get this code formatted as Markdown? It very difficult to read. Use triple backticks before and after the code.
Does the example work in the user interface?
At least there is one typo ("shpaes"), so I don't think this code every worked.
Sorry for the hard-to-read pure text format.
I hope this time it would be better.
More readable, but the typo is still there.
The issue is that symbolic layers aren't original layers. They are computed internally. In order to store such shapes you'll need to create new layers in the layout and use these for output.
Like (not tested):
@tagger5896
First, it's "Matthias"
Second: please don't indent your text - Markdown formatting will turn it into a code piece.
An third: the documentation (https://www.klayout.de/doc-qt5/manual/net_tracing.html) refers this this page for the description of the symbolic layers: https://www.klayout.de/doc-qt5/about/symbolic_layers.html
Gotcha new too the fourm thanks for the info
I am trying too get this code to work with no success
using another example as well posted in the documentation and I would like too save the output to another file
check_results.gds , the trace_result_cell_shapes is not writing too the check_results.gds.
I have an extensive Cadence Skill Eda background but this is all new
Enter your Ruby code here
layer_ids = {}
gds_layer = 100
tech.connection("9/0", "10/0", "11/0")
tracer.trace(tech, ly, ly.top_cell, RBA::Point::new(2600, 3100), ly.find_layer(9, 0))
trace_result_cell = layout.create_cell("E:/Klayout/si4all/samples/check_result.gds")
trace_result_cell.shapes(e.layer).insert(e.shape,e.trans)
gds_layer += 1
puts e.shape
layout.write("E:/Klayout/si4all/samples/check_result.gds")
Can't say I know anything about anything, but this:
"The layer id would be 10^9+1."
makes me wonder about stuff like:
can this expression be evaluated, if indeed it's put
in that literal form to "whatever receives it"?
is that billion-plus-one within range of the variable
(?) that's catching it? Why so huge a number when
there's, what, 256 layers times 256 datatypes in
GDS-II?
dick,
Ya I hear ya coming from a Cadence Skill background , trying too wrap my head around this syntax
i am so used to cv = geGetCellView() the sel = geGetSelectedSet() then and the command line sel~>??
@tagger5896 Please forget about Skill .. I have not attempted to replicate this API. I also don't want to. Be aware that most vendor specific concepts in the EDA industry are protected by copyright. So I cannot and will not copy that.
I could be more helpful if you'd explain what you're attempting to achieve. I see you're trying to create a cell, but why passing a file name for the cell name?
In your code there is at least one more bug: a "layer" is given by a layer ID (which is an integer number). A layer ID is prepared in the context of a layout from a layer specification (which is GDS layer/datatype and/or name). As you trace nets on one layout, but prepare a different layout for writing the shape, you need to translate the layer ID from the original layout to the target layout. So
Matthias,
Thanks for the explanation this achieves
what I was looking for I was just going by previous examples
listed in the forum as guidance.
Hi Matthias! @Matthias
-code:
puts("Start")
puts ("e.shape.type: #{e.shape.type}")
puts ("e.layer: #{e.layer} .e.cell_index: #{e.cell_index}")
if e.shape.type != 1
puts ("e.layer: #{e.layer} .ly.get_info(e.layer): #{ly.get_info(e.layer)} .ly.layer(ly.get_info(e.layer)) #{ly.layer(ly.get_info(e.layer))} .e.shape.layer: #{e.shape.layer}")
else
puts ("ly.get_info(e.layer):: ERROR")
puts("End")
-result :
Start
e.shape.type: 15
e.layer: 7 .e.cell_index: 4
e.layer: 7 .ly.get_info(e.layer): 51/200 .ly.layer(ly.get_info(e.layer)) 7 .e.shape.layer: 7
End
Start
e.shape.type: 15
End
Start
e.shape.type: 1
e.layer: 1000000001 .e.cell_index: 1525
End
Start
e.shape.type: 1
e.layer: 1000000007 .e.cell_index: 1525
End
-question: how can i get the e.layer is an integer number? i have bug puts (ly.get_info(e.layer)) when e.shape.type =1.
Best Regards,
shipfire (chipcom)
@shipfire First, please open a new discussion for such questions. This discussion is already old. Second, please use MarkDown for marking code. A line with triple backticks before and after the code works wonders (same as on GitHub for example).
Regarding the error, I assume that your net tracer script has symbolic (computed) layers. These generate shapes but do not map to layers from the layout. So
get_info
returns an error.Matthias
I see, Thanks @Matthias !
