The Layers menu will show you what's used in a cell, by BOLD face
on the used layers of the larger set.
I would like to get the same info in a copy/paste-able text for use in documentation, but I haven't found any such utility. Klayout obviously is keeping track; how to make it say, rather than show?
Nothing can't be done with a script
(Create a new macro in the IDE under "Ruby", paste this code and run it. The printout gives the BOLD layers of the currently selected cell.
Can this be used to get the actual layer name as well ie:metal1 ... metal2 etc
@tagger5896
if you have GDS, layer names are not available in the layout, so they cannot be retrieved from the layout database. You'll need some translation table which you can derive from the layer table in the layout view:
Exactly what I was looking for tyvm
