Hi Matthias and/or others,
I have a technology that is too wild to fit into one or more actual technologies. There are many different layer properties files that fall into this one technology. Too many designs. I will need to load a lyp file based on the gds file name at file_open or view_changed - which is no problem, I have done that. But I noticed that the user has no recourse if he/she accidentally clicks on a technology from the selector widget in the menu bar. They cannot re-load the initial layer arrangement (other than actually loading an lyp file via File>LoadLayerProp), and the only other option is to close the file and re-open. Is there an action from the technology selector widget I can use for that ? I would love to select and load an lyp file after the technology selector finishes all its actions, meaning (0) a file is opened and the right lyp is loaded, (1) the user clicks on a technology and messes it up that way, (2) the system loads that technology, including a dummy lyp file, (3) my code runs that inspects the view name and loads another lyp file.
Thanks.
Thomas.
Hi Thomas,
I'm sorry, but there is no such event currently. This has to be created first.
