Proof of Concept Router for Klayout
edited March 2021 in Python scripting
@Matthias @dick_freebird @MoBe
git hub is here https://github.com/hgroller/KlayoutRouter.git
All text locations must be on an int grid location
no float's at the present time
Layout is based on Matthias si4all dummy pdk
Code consists of :
place both files below in C:/Users/your_path/KLayout/pymacros
Router.py ----- in sys.path.append("C:/Users/your_path/KLayout/pymacros") and change your_path
AstarRouter.py
testroute.gds is the test gds file with Text placements
Load Router.py in the IDE with the testroute.gds file open, the run .
In AstarRouter.py you can play with blockages by adding 1's in the maze array
Have fun, Comments welcomed.
Tracy
