Is it possible to convert the GDS layout to 1 Bit TIFF with a 1um resolution. Almost like a raster form that can trace the design into pixels of a single layer.
Any help or guidance will be great.
Thanks.
Nakul
This one-liner script saves a 0,0 .. 200,150 µm box to a monochrome PNG file with 200 pixels width and 150 pixels height - hence 1µm resolution:
You can convert PNG to TIFF using one of the many image conversion tools (e.g. ImageMagick).
For more details about the "save_image_with_options" see here: https://www.klayout.de/doc-qt5/code/class_LayoutView.html#k_192
Thank you very much Matthias. Thanks for your quick response.
I shall look into this. I take it we can have a dialogue to ask the user to enter the file dimensions or a way to pick out the maximum layout dimensions. Will investigate it further.
Will there be an option in the future to extend the image file types.
Thanks.
Nakul
I tried the script, but it outputs a blank file. When I used save_image with the same parameters then I could see the image save in PNG format. Not sure what I was doing wrong. The save_image seems to be limited to 6400x6400 pixels, which doesn't capture the details I need in the layout.
I was also going through the past forums to see if this has been done before and found the following:
https://www.klayout.de/forum/discussion/476/is-there-any-api-supporting-generating-bitmap-out-of-gds/p1
However the page links in that thread were not working.
I have a GDS file with the dimensions of 50000x50000um with a <1um precision. This GDS layout I am trying to convert to TIFF which is readable for mask making.
Can you please guide me as to what I need to be doing to get the desired output from my Layout.
Thanking you in anticipation.
Nakul
The script line worked for me. Please make sure you are adjusting the box coordinates accordingly.
The PNG writer is a system-supplied one. I can't overcome it's limitations.
The forum links have change slightly. The discussion #167 link is: https://www.klayout.de/forum/discussion/167
But when you want to write masks, you should not use screenshot images. They are subject to optimization and accuracy is never better than +/- one pixel. A rasterizer is a different piece of software.
That looks to me like 2.5Gb (at 1 bit per pixel),
which is kind of chubby for an image file. It might
be overflowing some limit in a png->tiff conversion
script?
That's one way to get a null .tif file I reckon - just
give up for filesize (or allocated VM space).
Are you sure that the mask shop can't handle the
.png format? Supposed to be lossless, so why not?
Thanks Matthias and Freebird,
The mask shop was specific in saying that we need to supply 1Bit TIFF. They need to use external vendors or interface to convert from actually a DXF/DWG to TIFF.
They are aware of the size, just making life difficult for us.
For the rasterizer would you have any recommendations that work with KLayout.
Nakul
@Nakulh My general concen is a quality one, because the images are intended for display. So one pixel more or less is not much of a concern on a screen while it is on a mask. Pixels may also be shifted. Drawing speed is more important for screen display than quality, so the algorithm may compromise quality for speed.
A quality rasterizer should make some warranties about quality. I don't have a recommendation here - the mask makers I worked with all accepted polygon formats. KLayout has some code for quality rasterization of polygons (used for example in the fill tool), but that is not available as a user feature and will be a way slower. It computes the coverage percentage per pixel and you can choose to turn a pixel on for more than 50% coverage for example.
BTW: on Linux (Ubuntu 20.04LTS in my case), the conversion works flawlessly for 50000x50000 monochrome PNG. It's a matter of capabilities of libpng built into Qt. Memory peaks to a few GB during that process, but that's all.
Thanks Matthias,
That sounds like a promising solution. If you can point me to that code, I shall investigate it further.
Many Thanks.
Nakul
What do you mean? Using Linux with a better libpng?
Or do you mean the rasterizer. If you're familiar with C++ you can take a look here: https://github.com/KLayout/klayout/blob/master/src/db/db/dbPolygonTools.h (function "rasterize"). But that API isn't open (means: no warranties) and you'll still need to know how to merge (remove overlaps) a layout and turn it into a sequence of polygons. Plus how to code a loop and a bitmap collector for turning the per-polygon area map into pixels in a large bitmap. And finally you'll still need a TIFF writer capable of handling large bitmaps.
Thanks Matthias,
Highly appreciated. It was the rasterizer I was after and shall certainly try this uphill task. Thanks for sharing the link, you are truly knowledgeable.
Nakul
