In LEF you may have different CUTCLASS for different sized cut layer shapes. Is it possible to map the different CUTCLASS shapes to different datatypes using the layer map when reading in from LEF/DEF? Some PDKs require this.
https://github.com/KLayout/klayout/tree/master/testdata/lefdef/viasize
Thanks to Stefan I was able to get this working in https://github.com/The-OpenROAD-Project/OpenROAD-flow-scripts/pull/432
