I am using the Layer Mapping Table to import a layout from a technology to another. A predefined target layer would be nice : delete
I wish to import all layers and add at the end the match layers not defined in my list match:target (as it is right now).
But for some of them, I would prefer to delete them. Of course, I can do it later in an other step, but it would be nice to delete some known match layers at the GDS reading.
Thanks, BRgds,
Hi Laurent,
you can already do something like this:
This will read all layers, then specialize for layer 2/0 and 3/0 to map to 1002/0 and 1003/0 and finally unmap 6/0.
Note that "Read all layers" is turned OFF so that 6/0 is not counted as "other layer".
However, when you use this editor, it will turn this list into the logically equivalent, but garbled version:
