I have embedded 9 user properties with shapes on a layer (29/0), and succeeded in extracting them back out. However, I would need the As-Seen-In-Top coordinates, and I am not entirely sure how to do that in this Query format. This is how far i got:
select cell_name, shape.bbox.center.x/1000, shape.bbox.center.y/1000, shape.property(0), shape.property(1), shape.property(2), shape.property(3), shape.property(4), shape.property(5), shape.property(6), shape.property(7), shape.property(8) from shapes on layer 29/0 from instances of * where len(shape.property(1))>3
Can anyone help me trying to tickle out the translated coordinates ?
Thanks.
Thomas.
Hi Thomas,
there is a function called "path_trans" which will give you the (DBU unit) transformation into the top cell.
I'd suggest this solution:
This also shows how to use variables ("var ...;" is injected before the first expression to set the "b" variable). This shortens the expression somewhat.
I have also made a reference to layout.dbu instead of dividing by 1000. This solution is more universal.
BTW: I apologize for the bad error messages in the expression parser. It's syntax is too flexible ..
beautiful ! worked nicely ! THANK YOU !
can you have multiple of these search and replace actions in one ? I also use it to move fill shapes to another layer, and I need to do this for several layers. For some reason, I can never do more than 1 line.
Very good
On the other hand - sorry, there is only a single line. You can stash your query in the list below and restore it if that is helpful.
Basically, queries can also be issued from Python, like this:
here my query is
with shapes on layer 67/20 from cells * do shape.box = shape.bbox
. Please substitute yours.You can wrap that in a loop an execute multiple queries sequentially.
