Hi sir,
When Ruby DRC , I want to hide some of layer or show some of layer , or hide/show all the layers.
how can I do / what the command I can do referenece?
This makes me think that a "mapping" of every menu-tree button
to a Python and a Ruby code-snippet (one line maybe, for native?)
would be a valuable resource. Or maybe it exists already and is
not as obvious as could be.
@jiunnweiyeh You can't (or rather shouldn't) do that in DRC. DRC is meant as being independent from the UI, so it cannot access the UI elements by design.
Perhaps this is more a job for the DRC deck-creator, to add
"switches" which enable / disable "classes" of DRC (like,
I might see latchup rules enabled separately from plain
polygon width / space / nest / avoid, and so on).
It could get "busy" of course. But you might also be able to
insert a bit of "layer massaging" in the front of the layer-derivation
(paste in blockwise) to do different tasks if these turn out to be
common enough, to be worth the effort. Like if you don't want a
layer checked, just don't derive it. Although that will probably
inform you of the next set of script-errors, to then go chase, ....
You could also go to the effort of making a flat layout and
removing any layers you didn't want to check (but see last
paragraph).
Hmm ... I understood it differently in a way that the intent is to generate layer display styles from inside a DRC script. That's something that is beyond the abilities of DRC (apart from ugly hacking).
paragraph).
Some clarification was helpful.
