Modifying default parameters is invalid
edited May 2023 in Python scripting
import math
This sample PCell implements a library called "MyLib" with a single PCell that
draws a circle. It demonstrates the basic implementation techniques for a PCell
and how to use the "guiding shape" feature to implement a handle for the circle
radius.
NOTE: after changing the code, the macro needs to be rerun to install the new
implementation. The macro is also set to "auto run" to install the PCell
when KLayout is run.
class Parray(pya.PCellDeclarationHelper):
  The PCell declaration for the circle
  def __init__(self):
    super(Parray, self).__init__()
    # declare the parameters
    self.param("l", self.TypeLayer, "Layer", default = pya.LayerInfo(1, 0))
    self.param("ref", self.TypeShape, "", default = pya.DPoint(0, 0))
    self.param("shp", self.TypeShape, "", default = pya.Polygon([pya.DPoint(-500, -500),pya.DPoint(1000, 0),pya.DPoint(0, 1000)]))
    self.param("rownum", self.TypeInt, "Row Number", default = 4)
    self.param("rowx", self.TypeInt, "Row X", default = 0)
    self.param("rowy", self.TypeInt, "Row Y", default = 50)
    self.param("rowm", self.TypeInt, "Row Mag", default = 1)
    self.param("rowa", self.TypeInt, "Row Ang", default = 0)
    self.param("colnum", self.TypeInt, "Col Number", default = 4)
    self.param("colx", self.TypeInt, "Col X", default = 50)
    self.param("coly", self.TypeInt, "Col Y", default = 0)
    self.param("colm", self.TypeInt, "Col Mag", default = 1)
    self.param("cola", self.TypeInt, "Col Ang", default = 0)
  def display_text_impl(self):
    return "Parray(L=" + str(self.l) +  ")"
  def coerce_parameters_impl(self):
   pass
  def can_create_from_shape_impl(self):
    # Implement the "Create PCell from shape" protocol: we can use any shape which
    # has a finite bounding box
    return self.shape.is_polygon()
  def parameters_from_shape_impl(self):
    # Implement the "Create PCell from shape" protocol: we set r and l from the shape's
    # bounding box width and layer
    self.shp =self.shape.dpolygon
    self.ref = self.shape.bbox().center()
    self.l = self.layout.get_info(self.layer)
  def transformation_from_shape_impl(self):
    # Implement the "Create PCell from shape" protocol: we use the center of the shape's
    # bounding box to determine the transformation
    return pya.Trans(pya.Point(0,0))
  def produce_impl(self):
    # fetch the parameters
    self.cell.shapes(self.l_layer).insert(self.shp)
    for j in self.cell.shapes(self.l_layer).each():
      self.shp=j.dpolygon
    for j in range(rownum):
     for k in range(colnum):
      tt=pya.DCplxTrans(self.rowx*j+self.colx*k, self.rowy*j+self.coly*k)
      self.cell.shapes(self.l_layer).insert(tt.trans(self.shp))
class MyLib(pya.Library):
  The library where we will put the PCell into
  def __init__(self):
    # Set the description
    self.description = "My First Library"
    self.layout().register_pcell("Parray", Parray())
    # That would be the place to put in more PCells ...
    # Register us with the name "MyLib".
    self.register("MyLib")
MyLib()
  • edited May 2023
    Why is changing the default parameters invalid here
    # Enter your Python code here
    import math
    # import klayout.db as db
    radius.
    ly = pya.Layout()
    top_cell = ly.create_cell("TOP")
    class Pnumber(pya.PCellDeclarationHelper):
      def __init__(self):
       # global nstart,nend,nstep,nmag,ngap
        super(Pnumber, self).__init__()
        self.param("nstart", self.TypeInt, "Number_Start", default = 1)
        self.param("nend", self.TypeInt, "Number_End", default = 10)
        self.param("nstep", self.TypeInt, "Number_Step", default = 3)
        self.param("nmag", self.TypeInt, "Number_Mag", default = 100)
        self.param("ngap", self.TypeDouble, "Number_Gap", default = 20.0)
        return "Pnumber(L=" + str(self.l) +  ")"
       pass
        # self.shp =self.shape.dpolygon
        i = self.nstart
        n_now = self.nstart
        for self.n_now in range(self.nstart,self.nend):
          parameters = {
          "layer": pya.LayerInfo(1,0),
          "mag": self.nmag,
          "text": n_now
          n_now = i * self.nstep + 1
          print(n_now)
          cell = ly.create_cell("TEXT", "Basic", parameters)#TEXT表示创建的是文本类
          y = 0.0
          x = self.n_now * self.ngap
          print(x)
          top_cell.insert(pya.CellInstArray(cell.cell_index(), pya.DTrans(x,y)))
          # DTrans创建的一定是浮点型
          i += 1
          print(i)
      def __init__(self):
        self.layout().register_pcell("Pnumber", Pnumber())
    MyLib()
  • edited May 2023
    @zhenganqi Sorry, I don't understand. Please help me. What is the problem?
    And please mark Python code with a triple backtick line before and after so it gets formatted as code. Like on github. I took the liberty to edit your post.
  • Maybe some things are "baked in" and if you want to change
    the recipe, you have to go all the way back to making dough?
  • If you want to make a cake that is different from the one you just got - than that's the right approach :)
