Before knowing this warning, I unthinkingly upgraded Ventura and Xcode to 13.6 and 15.0, respectively.
Due to this issue, I could not build KLayout 0.28.12 on Ventura, and the next DMG set will not include those built on Ventura.
I will wait for an official update from Homebrew.
If you are interested, please try to use one built in Monterey.
Thank you for sharing your experience.
I've also applied the patch manually, following the steps captured here. And the build was successful.
Four additional DMGs are up.
Supplemental:
I have also confirmed that this patch is required in the above-said environment.
That is, in a relatively old Qt and relatively new compiler (clang) combination.
The build was done in expert mode.
I missed your warning
KLayout 0.28.12on Ventura, and the next DMG set will not include those built on Ventura.I will wait for an official update from Homebrew.
Hi @StefanThiede,
qt@5.15.11
I have confirmed that Homebrew has applied the patch in qt@5.15.11.
By upgrading to qt@5.15.11, patching is no longer required.
Qt 5.12.8 and Clang-17 on Linux Mint 20.3
Supplemental:
