Enhancements: DXF's circle approximation can now also specified through an "accuracy" parameter:
if less than the number of specified points is required to achieve the given accuracy, the number
is reduced accordingly.
This also applies to the polygon interpolation of spline and arc curves.
Thank you Matthias, especially for "Bugfix: Copying Hierarchy treets containing PCell's made the PCell's being turned into static cells."
It works well as expected!
Thank you for this release.
Especially related to MyPost.
This works fine as I expected.
Kazzz
Hi guys,
very good :-) Thanks for your feedback. I'll have another "mission accomplished" beer :-)
