How can I write texts that can be fabricated in my wafer?
edited January 2018 in Layout
I am trying to use texts for labelling in my wafer. As it has many components, it would be easier to distinguish components.
I found this discussion on the forum but it wasn't helpful for me. So can someone please guide me with this?
Found discussion: https://www.klayout.de/forum/comments.php?DiscussionID=225
    I found it myself at http://klayout.de/forum/comments.php?DiscussionID=439&page=1#Comment_1873
    thanks!
    The above forum post is concerning doing it via script.
    The easiest way is through the GUI:
     Edit | Mode | Instance (or push Instance in the toolbar)
    choose the Library = Basic
    choose the Cell = TEXT
    click on PCell, then enter your desired Text.
    Choose the physical layer you want the text to appear on.
    Also note that the text has to be design rule clean if it appears on the wafer. DRC violations can wreak havoc in the fab (low yield etc.). So I made myself a simple alphabet which has worked from 400nm through 28nm.
    Thank You for your comments. It really helped.
  • edited May 2018
    Hi Everyone,
    I'm resuming this topic because I can't access the link kindly provided by photonicbishal (might be deprecated).
    While I'm aware of how to instantiate PCells via the Klayout GUI, I would like to know how to instantiate a text PCell using a Python macro.
    All the best, and thank you Matthias for all the hard work!
  • Hi sirfumi,
    I had to upgrade to a new version of the forum software. Because of this, the link format has changed:
    becomes
