is there a way to iterate through all DRC error "Groups" markers and make one single screenshot of a single violation from this Group (just to give an example of the violation)?
I would be looking for an automated (scripted) way to do it since I have 33 gds files with RDB DRC results I need to comment on
I would further more need to translate this results including the snapshots to an excel sheet or html report.
Any idea?
Thank you,
Best Regards,
Martin
Hi, Martin!
If you use Python for scripting, I could recommend to use XLSXWriter for Excel reports generation.
Hi Martin,
creating the screenshots is possible, but I have no experience with writing Excel sheets with images.
Some code for generating screenshots and producing HTML is found in this example: https://www.klayout.de/examples/screenshots.html
Hi guys,
thank you for your hints. I found a ready to use mentor feature which is also generating a HTML report (quite nice actually). Nevertheless I would like to do it next time in Klayout since I truly love this tool.
Thanks Matthias for this master piece.
BTW (offtopic): is it possible to run drc layer generation hierarchical? I just got it running with "flattened" results.
Best Regards,
Martin
Hi Martin,
basically there is a hierarchical mode. Just add a line in front of your DRC script:
Please note that the implementation is somewhat restricted. It works nicely for "well-behaving" hierarchies. It's mainly intended as preprocessing step for LVS. In the general - or nasty - hierarchical case, performance or memory footprint may suffer.
For more details see here: https://www.klayout.de/doc-qt5/manual/drc_runsets.html#h2-718
