Hi, Matthias!
Are there any serious reasons, like old compiler(s), that prevent to switch C++11 or C++14?
It's also make sense to modernize code and Clang-tidy's modernize checks could automate transition. Compile database could be made with Bear or it's more advanced version (please note, that it's not installed with Clang :-(, you need to use it from source code).
Yes, I have a reason. CentOS6 for example which is still out there and used a lot.
I would like to add my support for "long tail" compatibility.
One of my over-arching interests in klayout is that it can be
"stood up" (compiled) for a wide range of systems / OSes.
I have zero, or less than zero, need to chase the latest shiny
object (oriented language version).
Current setting is -std=0x which means -std=c++11 (with some limitations) in older compilers.
