Hello, I am trying to learn the concepts in LVS and device extraction. I am using an LVS script to automatically generate netlists.
I have a basic question. I don't understand why the resistance reduces to half even though I connect the resistors in series (or at least I think I connect them in series
 . But it looks like they are connected parallel)
The following layouts consist of two resistors. One of them has separate and the other has connected resistors. When I produce the netlist you see the resistance values as 10.32 and 5.16. I don't understand why resistance reduces to half when I connect these two resistors. Shouldn't they become a single resistor with resistance doubled (since they are connected in series. -or am I wrong? Are they actually parallel?)
If you can make an explanation it would be really helpful! (By the way is there a reference (book etc. ) where I can check how basic electronic components in layout view look like? (Instead of the logical view)
PS: This is the LVS code I use to automatically generate netlists
target_netlist("resistor2.cir", write_spice, "Created by KLayout")
deep
# Produce LVS report
report_lvs
res_layer = input(1,0)
contact_layer = input(2,0)
bulk = polygon_layer
sheet_rho = 1
model_name = "RES"
extract_devices(resistor(model_name, sheet_rho), { "R" => res_layer, "C" => contact_layer })
connect(res_layer,contact_layer)
#connect_global(bulk, "SUBSTRATE")
report_netlist("resistor.l2n")
# Netlist normalization
netlist.simplify
Whether they are series or parallel depends on
whether the endcaps are the same net or different.
The netlisting appears to think they are the same
net. But "why?" is probably the question.
Now there's something funny about the two
endcaps of both resistor segments, as if perhaps
the "longer" one is also contacting "something"
(NWell? Substrate? Or just a non-identical detail
layout?) as is the norm on implanted resistors
of single stripe - one contact also grabs the
isolation region. Then if the isolation is treated
as a "local global net" (i.e. extraction logic calls
it an ohmic short) than permute-parallel rules
(forget what klayout calls this) might give you
the outcome you're seeing.
Following and testing results are here code follow's
The test gds can be found here
https://github.com/hgroller/test_res
Ege_Bey,
You can find more info located here, Matthias has provided a dummy pdk.
https://github.com/klayoutmatthias/si4all.git
Tracy
Hello! Sorry for my late reply! Thank you very much for your help and providing this nice resistor layout and the code
Ege_Bey,
Any time this was buried in the forum and many thanks to Matthias for providing the dummy pdk
@tagger5896
Thanks for the sample. To be frank it seems to be working, although it produces each resistor in a separate cell because that's how it was designed.
If you want to get rid of the RES2 device cell, use this:
I have also added this
At the beginning which gives me this nice netlist view:
In this case, resistors don't get combined as the middle node is a pin.
When I remove the "OUT" labels, this pin is gone and I get a nice combination of the resistory in series:
So my conclusion is that it's working.
In your previous case, I think the problem was that you shortened the resistors by connecting the resistor layer (which is essentially the body) and the contacts. This makes the body a conductive layer which shorts everything:
This is also the reason why "R$1" in your right netlist is connected to net "1" with both terminals.
Classic joke (KiCad version):
@Matthias,
Thanks for the valuable input,
I am still learning Klayout in's and outs .
Tracy
