I am working to fabricate a few thousand identical devices on a wafer and add a text PCELL to each device cell which will denote its unique serial number (e.g., from 0001 to 9999). Having a unique serial number is useful for diagnosing issues post fabrication.
So far, I drew up a device cell and I filled a 6 inch wafer layer with it using the Fill Tool. But, I am having trouble figuring out how to add the serial number text PCELL. Since there are many devices, I cannot do this by hand.
I have two ideas for how to script these serial numbers with python:
Which method is better, and how would I implement it in a script? For reference, I am attaching an example GDS file showing how far I have gotten.
Side note: This problem has come up in this topic about 6 years ago. The conclusion there was a rather ugly and inconvenient solution of using excel files. I would like to instead do everything through a python script, since Klayout's python scripting has come a long way since 2015. Moreover, my actual device has 3 different subparts which each need their own serial number, so this excel solution is not robust enough.
Hi @fruitspunchsamurai
The second method will not work as you cannot change a PCell per instance. You can change it only once which will make all device instances use the same number.
So the first method is the only way to do that. The procedure is this:
With these assumptions here is a script which generates the serial number PCells:
P.S: after posting this script I noticed you wanted to have Python. This script is Ruby. It's straightforward to translate except the sorting function for which no equally elegant solutions exists in Python AFAIK.
Thank you Matthias! Your script worked very nicely, I have converted it to Python below for others to benefit from and put it also in the attached zip file.
PS There is a very short one liner to do the sorting in python, which IMHO is more elegant than in Ruby
@fruitspunchsamurai Thank you for the conversion.
But I disagree in one respect: Python's sort key feature is not a compare function, but just a key selector. I found that quite limited. If you insist on a challenge, here is the short Ruby version
With a bit of monkey patching you can even sort by Points directly:
I actually thought that the starship operator is provided automatically by Ruby but that's not the fact. I'll need to check that.
